精美逼真的3D魔方游戏实现,基于虚幻引擎的C++代码
发布时间:2023-12-19 16:29:50 浏览量:177次
UE5编写的3D魔方益智小游戏。游戏界面和游戏控制是很值得学习的。借助本游戏源码你可了解一些用UE5编写游戏的基础技巧。
虚幻5c++生成魔方
一、绘制魔方
我们需要绘制一个3x3的魔方,共9个,每个方块的大小为1x1x1,并且魔方的中心点在坐标(0, 0, 0)。
代码如下:
class MOFANG2_API AMoFangActor : public AActor
GENERATED_BODY()
public:
// Sets default values for this actor's properties
AMoFangActor();
int CubeColor[6][10][10][10];
UPROPERTY(EditAnywhere)
int Jie =3;
UPROPERTY(VisibleAnywhere)
TArray<UStaticMeshComponent*> CubeComponent;
UStaticMesh* CubePlaneStaticMesh;
//设置六面材质
TArray<UMaterialInterface*> MediaTextureMat;
protected:
// Called when the game starts or when spawned
virtual void BeginPlay() override;
public:
// Called every frame
virtual void Tick(float DeltaTime) override;
virtual void Create3DMofang();
AMoFangActor::AMoFangActor()
// Set this actor to call Tick() every frame. You can turn this off to improve performance if you don't need it.
PrimaryActorTick.bCanEverTick = true;
//三维魔方生成
for (int i = 0; i < Jie * Jie * Jie; i++)
CubeComponent.Add(CreateDefaultSubobject<UStaticMeshComponent>(FName(FString::Printf(TEXT("Mesh 1%d"), (i)))));
CubeComponent.Add(CreateDefaultSubobject<UStaticMeshComponent>(FName(FString::Printf(TEXT("Mesh 2%d"), (i)))));
CubeComponent.Add(CreateDefaultSubobject<UStaticMeshComponent>(FName(FString::Printf(TEXT("Mesh 3%d"), (i)))));
CubeComponent.Add(CreateDefaultSubobject<UStaticMeshComponent>(FName(FString::Printf(TEXT("Mesh 4%d"), (i)))));
CubeComponent.Add(CreateDefaultSubobject<UStaticMeshComponent>(FName(FString::Printf(TEXT("Mesh 5%d"), (i)))));
CubeComponent.Add(CreateDefaultSubobject<UStaticMeshComponent>(FName(FString::Printf(TEXT("Mesh 6%d"), (i)))));
void AMoFangActor::BeginPlay()
Super::BeginPlay();
Create3DMofang();
FVector center = FVector((i % Jie) * 100 - 100, ((i / Jie) % Jie) * 100 - 100, ((i / Jie / Jie) % Jie) * 100 - 100);
//上
if (CubeColor[0][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie] != -1)
CubeComponent[i * 6 + 0]->SetupAttachment(RootComponent);
CubeComponent[i * 6 + 0]->SetStaticMesh(CubePlaneStaticMesh);
CubeComponent[i * 6 + 0]->SetMaterial(0, MediaTextureMat[CubeColor[0][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie]]);
CubeComponent[i * 6 + 0]->SetRelativeLocationAndRotation(center + FVector(0, 0, 50), FRotator(0, 0, 0));
CubeComponent[i * 6 + 0]->RegisterComponent();
//下
if (CubeColor[1][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie] != -1)
CubeComponent[i * 6 + 1]->SetupAttachment(RootComponent);
CubeComponent[i * 6 + 1]->SetStaticMesh(CubePlaneStaticMesh);
CubeComponent[i * 6 + 1]->SetMaterial(0, MediaTextureMat[CubeColor[1][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie]]);
CubeComponent[i * 6 + 1]->SetRelativeLocationAndRotation(center + FVector(0, 0, -50), FRotator(180, 0, 0));
CubeComponent[i * 6 + 1]->RegisterComponent();
if (CubeColor[2][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie] != -1)
CubeComponent[i * 6 + 2]->SetupAttachment(RootComponent);
CubeComponent[i * 6 + 2]->SetStaticMesh(CubePlaneStaticMesh);
CubeComponent[i * 6 + 2]->SetMaterial(0, MediaTextureMat[CubeColor[2][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie]]);
CubeComponent[i * 6 + 2]->SetRelativeLocationAndRotation(center + FVector(0, -50, 0), FRotator(0, 0, 270));
CubeComponent[i * 6 + 2]->RegisterComponent();
if (CubeColor[3][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie] != -1)
CubeComponent[i * 6 + 3]->SetupAttachment(RootComponent);
CubeComponent[i * 6 + 3]->SetStaticMesh(CubePlaneStaticMesh);
CubeComponent[i * 6 + 3]->SetMaterial(0, MediaTextureMat[CubeColor[3][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie]]);
CubeComponent[i * 6 + 3]->SetRelativeLocationAndRotation(center + FVector(0, 50, 0), FRotator(0, 0, 90));
CubeComponent[i * 6 + 3]->RegisterComponent();
//前
if (CubeColor[4][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie] != -1)
CubeComponent[i * 6 + 4]->SetupAttachment(RootComponent);
CubeComponent[i * 6 + 4]->SetStaticMesh(CubePlaneStaticMesh);
CubeComponent[i * 6 + 4]->SetMaterial(0, MediaTextureMat[CubeColor[4][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie]]);
CubeComponent[i * 6 + 4]->SetRelativeLocationAndRotation(center + FVector(-50, 0, 0), FRotator(90, 0, 0));
CubeComponent[i * 6 + 4]->RegisterComponent();
//后
if (CubeColor[5][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie] != -1)
CubeComponent[i * 6 + 5]->SetupAttachment(RootComponent);
CubeComponent[i * 6 + 5]->SetStaticMesh(CubePlaneStaticMesh);
CubeComponent[i * 6 + 5]->SetMaterial(0, MediaTextureMat[CubeColor[5][i % Jie][(i / Jie) % Jie][(i / Jie / Jie) % Jie]]);
CubeComponent[i * 6 + 5]->SetRelativeLocationAndRotation(center + FVector(50, 0, 0), FRotator(270, 0, 0));
CubeComponent[i * 6 + 5]->RegisterComponent();
void AMoFangActor::Tick(float DeltaTime)
Super::Tick(DeltaTime);
void AMoFangActor::Create3DMofang()
for (int col = 0; col < 6; col++)
for (int i = 0; i < Jie; i++)
for (int j = 0; j < Jie; j++)
for (int k = 0; k< Jie; k++)
CubeColor[col][i][j][k] = -1;
//上九个面
CubeColor[0][i][j][2] = 0;
//下九个面
CubeColor[1][i][j][0] = 1;
//左九个面
CubeColor[2][i][0][j] = 2;
//右九个面
CubeColor[3][i][2][j] = 3;
//九个面
CubeColor[4][0][i][j] = 4;
//九个面
CubeColor[5][2][i][j] = 5;
