Auto CAD中"Φ”尺寸及上下公差怎么标注?
2024-02-08 18:31:00
来自落后忘戒指的回答 2024-02-08 20:07:16
1、新建一个文本文档,将下列字符复制其中保存,并将其后缀名改为LSP放到CAD子目录下;字符:标注的快捷键(DEFUN C:DD()(COMMAND "dimlinear"))垂直标注公差复制内容到剪贴板 (defun c:czc() (setq p1 (getpoint " 请输入标注起点:")) (setq p2 (getpoint " 请输入标注终点:")) (setq d21 (cadr p1)) (setq d22 (cadr p2)) (setq d1 (getstring " 请输入标注尺寸:")) (setq d2 (abs (- d21 d22))) (setq s (getstring " 输入上公差:") x (strcat "^" (getstring " 输入下公差:"))) (if (= s "0") (setq s " 0")) (if (= x "^0") (setq x "^ 0")) (if (/= d1 "") (setq dd (strcat "%%c" d1 "{" "\" "H0.7X" ";" "\" "S" s x ";" "}" )) (setq dd (strcat "%%c" "" "{" "\" "H0.7X" ";" "\" "S" s x ";" "}" ))) (command "dimlinear" "ve" p1 p2 "T" dd) ) 2、加载lisp文件,加载完成后,重启CAD软件。 3、标注步骤:1)在输入栏输入快捷键CZC;2、点击要标注的上端点;3)点击要标注的下端点;4)输入要标注的尺寸;(若为默认尺寸,该步骤则右键点击)5)输入上公差数值,按回车键结束;6)输入下公差数值,按回车键结束;7)点击放置标注的位置,标注完成。
